Activity Forums Apple Final Cut Pro Legacy What resolution would be best?
  • What resolution would be best?
    Posted by Annu Lilja on January 5, 2009 at 8:20 pm
    Hi, I will be editing a project that will be shot on Red. The assistant editor is suggesting that he will send me the offline material as 1280×720 or as 1920×1080. He seems to think that 1280×720 will definitely be good enough. I will be editing on my laptop and I have FCP 6.0.4. What resolution do you suggest I ask for?
    Thank you all kind people in advance : )
    Asher Castillo replied 17 years, 8 months ago 4 Members · 3 Replies
  • Jerry Hofmann
    January 5, 2009 at 8:30 pm
    What’s the delivery format to be?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Shane Ross
    January 5, 2009 at 9:51 pm
    For OFFLINE editing? Heck, DVCPRO HD 720p would be just fine. Matching frame rate to what you shot, of course.
    They did this for ZODIAK…major feature. And JARHEAD.
    Shane
  • Asher Castillo
    January 6, 2009 at 12:56 am
    Check out editing Red in FCP using the red proxies. The medium proxy is 720p I believe. You should be able to find all the necessary work flows on Red’s site.
