Activity Forums DaVinci Resolve what QT codecs are supported?
  • what QT codecs are supported?
    Posted by Nat Jencks on January 6, 2011 at 11:46 pm
    Hi guys, I am trying to load quicktimes for offline reference, and have found that neither dnxhd and motion jpeg seem to work. H264, and prores both work.
    I can’t find documentation about which quicktime codecs are supported. Can anyone point me in the right direction.
    best-
    Nat
    Nat Jencks replied 15 years, 8 months ago 3 Members · 5 Replies
  • Margus Voll
    January 7, 2011 at 5:57 am
    Have you made files on pc ?
    Motion jpg seems like pc file.
    Margus
    https://iconstudios.eu
  • Blase Theodore
    January 7, 2011 at 4:01 pm
    Off the top of my head, here’s the formats that I know work from personal experience..
    (never tested PAL)
    If anyone sees one I missed, please add..
    • uncompressed (all flavors)
    • DVCProHD
    • XDCam EX (and probably all flavors)
    • Prores (all flavors)
    • DnxHD (only tested 220 – requires $500 avid support ad-on)
    • H264
    • DV
  • Nat Jencks
    January 7, 2011 at 4:38 pm
    I tested animation codec which is sometimes referred to as uncompressed or “none”, and it didn’t work. Didn’t test any of the AJA flavors of uncompressed, etc.
    Ended up using prores.
    I take it you need the $500 avid codec package just to read avid codec quicktimes? That’s crazy!
    Every other application that supports quicktime reads avid codec fine. I guess I’ll transcode DHXhd material to prores for now. Seems like an unnecessary roadblock for avid users.
    -Nat
  • Blase Theodore
    January 7, 2011 at 4:45 pm
    Ehh, $500 honestly not such a bad deal after they threw in that $19,000 discount for Resolve.
    I’m guessing the old DaVinci probably charge $10k for that same “add-on”.
    Just sayin.
  • Nat Jencks
    January 7, 2011 at 4:50 pm
    no, these were made on a mac. I sometimes use motion jpeg A as a codec when I’m sending to old versions of quicktime, or quicktime on linux, etc.
    Prores seems to be working, as does H.264 quicktime. I guess Resolve is just a bit picky about what codec’s it supports. Weird, since for most applications, if quicktime player plays teh file, the application will also.
    -Nat
