Activity Forums Apple Final Cut Pro Legacy What preset for DVCPRO50 ?
  • What preset for DVCPRO50 ?
    Posted by Niklas Wikman on August 21, 2008 at 9:29 am
    I shoot 576i in 16:9 over P2 and DVCPRO50. But there’s no such preset in FCP 5.1.4 – only DVCPRO or DV50.
    What preset should I use (anamorphic should be checked if there’s 16:9)?
    And what is superwhite?
    Peter Hall replied 18 years, 1 month ago 5 Members · 7 Replies
  • 7 Replies
  • Tielman Dewaele
    August 21, 2008 at 10:07 am
    I got exactly the same problem.
    See post below.
    Do you have problems with quality loss?
    MacPro Intel Quad Core 4G Ram
    MacBookPro Intel Duo Core 2G Ram
    After Effects, Photoshop, Illustrator
    Cinema4D
    Final Cut Studio
    https://www.t-bloggy.blogspot.com/
  • Niklas Wikman
    August 21, 2008 at 11:44 am
    Not that I can see, but that’s mainly because I have not had any issue with this before.
    Before moving to P2, we shot Betacam SP and captured using a DSR-45P DV/DVCAM deck. Thus the codec was Apple DV, and it looked really really good. And sure, it was uncompressed analogue source.
    Surely the DV codec does compress quite much. Then going to DVCPRO50 (equal to Digibeta) on SD we believe the upcoming project would at least not look worse
  • Rafael Amador
    August 21, 2008 at 11:45 am
    DVCPro50 and DV 50 is the same.
    Rafael
    http://www.nagavideo.com
  • Rafael Amador
    August 21, 2008 at 11:52 am
    [Niklas Wikman] ” Then going to DVCPRO50 (equal to Digibeta”
    Both codecs are 422, but Digibeta is uncompress and DV50 is compressed. Higher quality, bigger files.
    [Niklas Wikman] “Betacam SP and captured using a DSR-45P DV/DVCAM deck. Thus the codec was Apple DV, and it looked really really good.”
    If you can capture Betacam to DV 50 will look much better, nd to 8b Unc or Proress, even better.
    Rafael
  • Herb Sevush
    August 21, 2008 at 1:49 pm
    DV50 is DVCPRO50. Use the DV50 anamorphic version if you shot 16×9. Super white is something you should stay away from, unless you have a specific reason not to. DVCPRO 50 16×9 looks great in FCP – have cut over 50 1/2 hour broadcast shows with it and everyone loves it – bumps up real nice to HD as well.
    Herb Sevush
    Zebra Productions
  • Niklas Wikman
    August 21, 2008 at 6:04 pm
    Thanks for your reply. I’ll go for DV50, then.
    (strange enough that QT does have a number of settings much more explained – there are both DVCPRO and DVCPRO50, HD, DV25, etc etc…)
  • Peter Hall
    August 22, 2008 at 8:52 am
    I have some long stationary takes of cityscapes that I would like to edit into a time lapse effect without doing the tedious work. Is there a plugin that can help with that? The source material is HDV 1080/50i from mini dv tapes and I am using FCP 5.14
