Activity Forums Apple Final Cut Pro Legacy What PCI-express cards are you using?
  • What PCI-express cards are you using?
    Posted by Harry Pallenberg on April 6, 2006 at 11:52 pm
    What PCI-express cards are you using? Specifiacally for a SATA raid. Are the Sonnet the only game in town?
    Harry.
    Forum Cowmunity Leader: OSX
    Forum Cowmunity Leader: Indie & Doc
    Dual 1.8 G5 ** 1GB ** 10.4.1
    Harry Pallenberg replied 20 years, 5 months ago 2 Members · 5 Replies
  • Mitchji
    April 7, 2006 at 5:21 pm
  • Mitchji
    April 7, 2006 at 5:29 pm
    The Sonnet Tempo SATA E4P is the first shipping four port external native PCI Express (PCIe) 4x SATA host adapter for PowerMac G5 Dual-Core models, which were released Oct. 19, 2005.
    Until recently, there was only one Macintosh PCIe SATA solution, which was the Highpoint RocketRAID. It uses a bridge board instead of a native PCIe interface. The Tempo SATA E4P allows the user to use Disk Utility to setup individual drives or a RAID, supports sleep mode, hot swap, passes SATA hard drive temperature data and is compatible with port multiplier enclosures. Many of these features are not available with the Highpoint solution.
    No Boot Capability
    The Sonnet Tempo SATA E4P does not have boot capability. FirmTek SATA host adapters provide this feature for PowerMac models with PCI or PCI-X slots. However, no company has released a PCI Express SATA host adapter for the Macintosh that supports booting so far.
  • Harry Pallenberg
    April 7, 2006 at 6:36 pm
    Are you using one? In mission critical situation?
    Harry.
  • Mitchji
    April 7, 2006 at 9:00 pm
    [Harry Pallenberg] “Are you using one?”
    Hi Harry,
    I am not using one. I thought the review might be helpful.
    It also states that there is one other card available that works with PCI-E so you not only have the review but a choice if it doesn’t work out.
    Best Wishes,
    Mitch
  • Harry Pallenberg
    April 7, 2006 at 10:09 pm
    The review is great.. thanks… aslo for any who care there is a thread on this very subject on Macgurus..
    https://www.macgurus.com/forums/showthread.php?t=21906
    Harry.
