Activity Forums Adobe Premiere Pro What o Do After Edit
  • What o Do After Edit
    Posted by Richard Vee on June 26, 2021 at 1:20 am
    I understand when you import a file you are just creating a link to the original file.
    When you drag it over onto the timeline a copy of it is made in the project panel.
    My question is what do you do with it after the edit,after you shorten it,color correct and SAVE. If I don’t want to leave it on the timeline can I drag it back to the bin? Do I “clear it”,,can I delete the original file and just keep the edited one?
    Also,can I keep an edited clip to use in another project?,,if so how?
    I’ve watched U Tube videos and I don’t see an an answer, so if anyone has a link to a tutorial,,GREAT !!
    Any help is much appreciated .Thank you,,,?
    Richard Vee replied 5 years, 2 months ago 2 Members · 2 Replies
  • Eric Santiago
    June 28, 2021 at 1:52 pm
    It’s a virtual file you can leave the sequence timeline in your project forever.
    Should be a common workflow when you are in this field.
    Make sure to give it a decent name for identification.
    Once you are happy with your edit, you can render for delivery.
  • Richard Vee
    June 28, 2021 at 7:41 pm
    Thanks Eric!!
