Activity Forums Adobe Premiere Pro what Nvidia card (Mac) for CS6?
  • what Nvidia card (Mac) for CS6?
    Posted by Russ Johnson on April 24, 2012 at 4:18 pm
    I read with interest the thread below about the possibility of Adobe supporting Radeon cards in MacPros, but I don’t have the option of waiting to see if it materializes. I am currently running a 5770 in my early 2008 Mac Pro w/16GB ram.
    It seems there are only three Nvidia cards available for the Mac that CS6 presently supports:
    GTX-285 – $300 approx. (only used that I can find).
    Quadro 4000 – $700-$800
    Quadro 4800 – $1000+
    Does anyone out there have direct experience with how CS6 runs with the GTX285 in a MacPro? Is this card going to be acceptable or will I be wanting to upgrade to the 4000 or 4800 in a month?
    Just looking to get a general idea of the performance spread.
    Oskar Ziemba replied 13 years, 7 months ago 6 Members · 11 Replies
  • 11 Replies
  • Tom Daigon
    April 24, 2012 at 6:16 pm
    I got a sneak peak at CS6 and have been getting great performance with BOTH PrP and AE. I am running the Quadro 4000. That would be my suggestion
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    Mac Pro 3,1
    8 core
    10.7.3
    Nvidia Quadro 4000
    24 gigs ram
    Maxx Digital / Areca 8tb. raid
    Kona 3
  • Chris Borjis
    April 24, 2012 at 7:13 pm
    concur with Tom.
    The Quadro 4000 is a great value and a workhorse with CS 5.5 / 6.0
    It is definitely worth the extra cash getting the extra performance
    over the GTX card.
    When you render, you hear the little fans speed up. Fun Stuff!
  • Russ Johnson
    April 24, 2012 at 8:58 pm
    Thanks for the recommendation guys.
  • Tom Daigon
    April 24, 2012 at 9:09 pm
    Glad to help.
    Tom Daigon
    Mac Pro 3,1
    8 core
    10.7.3
    Nvidia Quadro 4000
    24 gigs ram
    Kona 3
  • John-michael Seng-wheeler
    April 25, 2012 at 10:46 pm
    Just a quick note, the Quadro FX 4800 is an older and slower card then the Quadro 4000…. Nvidia dropped the “FX” tag and restarted the numbering with the new fermi cards.
  • Banks Meador
    April 28, 2012 at 12:21 am
    I currently have a 285 in three systems in my shop running 5.5. Should we invest in the 4000 (x3)?
    April 29, 2012 at 4:33 pm
    The Specs would imply that the Quadro is only marginally faster with Premiere then the 285. Probably not worth the upgrade cost.
    That’s from looking at the specs. Your actual results may be different.
    If you want to try it, buy one first, and make sure you can return the Quadro for a full refund if you don’t see enough performance boost.
    JM
  • Tom Daigon
    April 29, 2012 at 4:52 pm
    The 4000 is a speed demon when rendering in After Effects.
    Tom Daigon
    Mac Pro 3,1
    8 core
    10.7.3
    Nvidia Quadro 4000
    24 gigs ram
    Kona 3
    April 29, 2012 at 4:59 pm
    I forgot about that. That’s because it’s a workstation card and After Effects uses the OpenGL parts of the card, rather then CUDA, where it is only marginally faster then the 285.
    So to answer your question Banks, you really will have to try a Quadro in your workflow to see if it makes sense to buy one or not.
    Just a note, CS6 disables OpenGL for rendering, and uses it only for previews. CS5.5 and before use OpenGL for rendering and previews, which apparently can lead to problems.
  • Banks Meador
    April 30, 2012 at 11:01 pm
    Thanks to you both for your input. We’ll do just that – get one and see if it really makes a difference.
    Thanks again,
    Banks
