Activity Forums Creative Community Conversations What motion templates do you create for yourself?
  • What motion templates do you create for yourself?
    Posted by John Davidson on August 6, 2014 at 1:37 am
    Hey gang,
    What kinds of different effects, transitions, and generators do you create for yourself in motion? For example, we have a 6 frame Fade up from black generator that we drop at the top of every project – that also happens to be 30 frames long so that when zoomed out you can still see the generator in a timeline easily.
    Have any of you made those kinds of things for yourself? Curious what sort of ingenious little things we’ve all come up with.
    John
    John Davidson | President / Creative Director | Magic Feather Inc.
    Andreas Kiel replied 12 years, 1 month ago 5 Members · 4 Replies
  • Charlie Austin
    August 6, 2014 at 7:12 am
    Slate generator, red/green band generator, editable title generators, temp billing block, a few random effects. No idea what I’m doing really, so anything relatively easy. 🙂 I really need to dig a little deeper…
    ~ My FCPX Babbling blog ~
    ~”It is a poor craftsman who blames his tools.”~
    ~”The function you just attempted is not yet implemented”~
  • David Mathis
    August 6, 2014 at 2:47 pm
    Same as above, combine a few effects and publish select parameters. Kind of like saving a preset in After Effects but without the subscription. Me like that very much! 🙂
    I am an avid user of FCP X!
  • Dave Gage
    August 6, 2014 at 7:58 pm
    [John Davidson]
    Have any of you made those kinds of things for yourself?”
    Funny you mention this. No not yet, but my son is learning Motion. I’d like to create a motion background similar to what you see on cable news shows with shapes, color patterns and show name very slowly moving in the background and then cycling through. I would use it for instruction tutorials instead of keying out the blue screen and adding a still photo.
    Does anyone know of a template we could start with? (And then I could say “yes” to your question.)
    Dave
  • Andreas Kiel
    August 8, 2014 at 11:02 am
    I do (did) several title things, a very few generators and some effects.
    My non commercial subtitle templates are meanwhile used by several hundreds of happy people. 😉
    But there is something I can for sure recommend for everybody playing around with this kind of stuff.
    1) In an environment where more than 1 user is involved (regardless if on 1 machine or several) don’t use your new template immediately. Move it to “/Library/Application Support/Final Cut Pro/Templates.localized/” and the matching subfolder (i.e. Titles.localized). Take care of sub-groups like for example “my Titles”.
    2) If you experiment with Motion Templates you should edit the Motion XML and enter a build version (found at <build>). That might help you later to track changes you made across projects.
    3) You may enter a theme when saving the template. That could help you to get organized within FCP X.
    4) Entering a description can be helpful as well – though you don’t see it in FCP X.
    – Andreas
    Spherico
    https://www.spherico.com/filmtools
    “He who fights with monsters should be careful lest he thereby
    become a monster. And if thou gaze long into an abyss, the abyss will
    also gaze into thee.” – Friedrich Nietzsche, Beyond Good and Evil
