Activity Forums Adobe Premiere Pro What may be the “Correct” way to compile time lines from various different jobs complete with the effects?
  • What may be the “Correct” way to compile time lines from various different jobs complete with the effects?
    Posted by Bruce Klein on June 15, 2013 at 6:53 pm
    What may be the “Correct” way to compile time lines from various different jobs complete with the effects, dissolves and everything else onto one timeline to burn a DVD
    I brought in the video, audio, fx and everything it was supposed to. It was ‘White” colored on the timeline.
    Then there was this…
    Encore… It worked yesterday… This may be a little long so I apologize… I am creating a demo of one minute commercials I have produced. I was copying each time line then loading them on one new timeline in a new project. When I did the compilation this way it would allow encore to produce a dvd… The problem compiling in this manner did not bring any of the dissolves and transitions that were used in the original time line to the new project. So I would re enter them before linking to Encore.
    There are to many spots to do that now so I spoke with someone and was directed to import the timeline into a new project.
    When sent to Encore I got a message “error loading transcode preset“and the timeline was in the project window but did not appear in the monitor window where I used to see it come up to select the range… Since it is not there I can’t select anything.
    I have mixed the import time line (I brought in the video, audio, fx and everything it was supposed to. It was ‘White” colored on the timeline and just showed 1 video and audio track with all the fx etc) into the new Premiere Project with an existing regular timeline that was brought in in its entirety the way described above with out dissolves, etc…
    Did the mix cause the problem?
    I will go back and try it with out mixing sources…
    Premiere Pro CS 5.5 and Encore cs 5 that came with it…
    Any insight into this would be welcome as I have no solution presently…
    Sincerely
    I use Adobe Premiere Pro CS 5.5 on a IMAC 27, Intel core i5 2.7 GHz, 12 GB 1333 MHz DDR3… MAC OSX 10.6.8 I have a 2 2 Terabyte external drives also.
    Thanks in advance for your help.
    Bruce
    Bruce Klein replied 13 years, 2 months ago 4 Members · 5 Replies
  • Michael Krupnick
    June 16, 2013 at 8:27 am
    Bruce, output a flattened file of each spot and use those as your sources. This is a demo, not a Ridley Scott movie. It’s a simple edit if you make it an honest compilation of spots. If your work is good, that should be quite adequate.
  • Bruce Klein
    June 22, 2013 at 4:06 am
    At the risk of sounding ignorant, what is a flattened file?
    Each spot is between 1-1:30 minutes and I want to compile them on one timeline. There may be 20 different timelines to put together…
    Do I flatten them with a rolling pin?
    My apology for not knowing what you meant.
    ABK
    Bruce
  • Michael Krupnick
    June 22, 2013 at 5:16 am
    You’re saying that you want to put a number of spots (you don’t say how many), each no longer than 1:30, on a single timeline to burn a DVD. At least that’s what it looks like you’re saying. If you haven’t yet, you need to make a Quicktime movie of each finished spot with all fx (that’s flattening a file). Arrange them on a timeline in the order they’re supposed to play. Export a single full-length Quicktime movie of that assembly project. Send that to Encore to compile, compress, build and burn.
  • Walter Biscardi
    June 22, 2013 at 12:55 pm
    [Bruce Klein] “At the risk of sounding ignorant, what is a flattened file?”
    A quicktime or other movie file. You export each spot as a self contained file and then lay them all into a timeline back to back.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author, Chef.
    HD Post and Production
    Biscardi Creative Media
    Foul Water Fiery Serpent, an original documentary featuring Sigourney Weaver. US & European distribution by American Public Television
    MTWD Entertainment – Developing original content for all media.
    “This American Land” – our new PBS Series.
    “Science Nation” – Three years and counting of Science for the People.
    Blog Twitter Facebook
  • Bruce Klein
    June 23, 2013 at 9:58 pm
    Mike and Walt, Thank you for your assistance. I greatly appreciate your help.
    ABK
    Bruce
