Activity › Forums › Lighting Design › What light is this?
  • John Sharaf
    January 17, 2015 at 9:47 pm
    Hi Trey,
    Likely a Rosco Lite Pad mounted in the frame. Here’s a link:
    https://www.rosco.com/litepad/litepadHO.cfm?menuReturn=litepad
    Also there are many types of LED strips which you can customize into different uses from Lite Gear:
    https://www.litegear.com/
    Has a similar look and effect of Kino “Bar Fly” which is fluorescent vs. LED, but some of the other lights in the shot clearly are Kino Flo Products, I’m not exactly sure which one you’re asking about, but maybe these links will help you out.
    Good luck,
    JS
