Activity Forums Adobe Premiere Pro What Kind of Compatibility between elements & 2.0?
  • What Kind of Compatibility between elements & 2.0?
    Posted by Richard Milner on January 20, 2006 at 5:32 pm
    Supposedly one of the new features is that you can take a project that was started in elements and bring it over to PPRo 2.0.
    What are the ground rules for doing so? Does it track roll #’s and TC( both drop & non -Drop)?
    Does Bridge work with elements?
    Tim Kurkoski replied 20 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Tim Kurkoski
    January 20, 2006 at 7:42 pm
    Premiere Elements and Bridge don’t have any kind of interactivity that I know of.
    Bridge is basically a file browsing utility. It has features for metadata, and some interaction with other Adobe programs (it can initiate some automated process for Photoshop CS2, for example), but it’s not any sort of Swiss army knife type of program. What exactly are you thinking that it would do?
  • Richard Milner
    January 20, 2006 at 8:07 pm
    I thought I read in a press release that you could take an elements project into Pro somewhere? Did anyone else see this, or am I dreaming 🙂
  • Dave Friend
    January 20, 2006 at 8:49 pm
    Richard,
    I read that too. Wish I could find it again. My recollection is that you could open Elements projects with Pro. But I could be dreaming too.
    Dave
  • Tim Kurkoski
    January 20, 2006 at 9:59 pm
    I just tried it (caveat: I’m still running beta of PP), and it works. It forces you to convert the Elements project to a Pro project, but it does work.
  • Zac Lam
    January 21, 2006 at 2:16 am
    Yes, it opens both Elements 1.0 and 2.0 projects. The conversion is a safeguard, forcing you to choose a new name, so you don’t accidentally save over your Elements project.
  • Richard Milner
    January 21, 2006 at 2:18 am
    [Timothy Kurkoski] “I just tried it (caveat: I’m still running beta of PP), and it works. It forces you to convert the Elements project to a Pro project, but it does work.”
    Does elements use timecode if it is on the tape?
  • Tim Kurkoski
    January 23, 2006 at 9:52 pm
    Yes, Elements captures timecode data just like Premiere Pro. They use the same capture engine. (Most of the differences between the programs are in the interface and the features. Very little of what makes the programs tick is different.)
