Activity Forums Audio What is TRS?
  • What is TRS?
    Posted by Miles King on May 10, 2005 at 6:56 pm
    Hi everyone,
    I’m buying a snake and I’m wondering what TRS is… I’m so used to 1/4″ and XLR but a lot of the snakes offer TRS but I’m confused as to what it stands for – the snakes still look like 1/4″ or XLR. Thanks!
    -Limelite
    Ronaldbeal replied 21 years, 4 months ago 4 Members · 3 Replies
  • John Fishback
    May 10, 2005 at 7:19 pm
    TRS stands for Tip Ring Sleeve (I believe this nomenclature originated in telephone operations). It describes the three contacts on a 1/4″ jack. The tip is the contact at the tip, the next contact is ring and the longest contact is the sleeve. In a balanced connection, typically, tip is high, ring is low and sleeve is ground.
    Here’s a site that goes into more detail: https://encyclopedia.lockergnome.com/s/b/Phone_plug
    John
    Dual 2.5 G5 4 gigs RAM OS 10.3.8 QT6.5.2
    Cinema 23 Radeon 9800
    FCP4.5 DVDSP 3.0.2
    Huge U-320R 1TB Raid 3 firmware ENG12.BIN
    ATTO UL4D driver 3.20
    AJA IO driver 1.3.1 firmware v21-26
  • Thaxter Clavemarlton
    May 10, 2005 at 9:52 pm
    JRF’s TRS explanation is AOK 😉
    But he failed to point out that TRS is a specific KIND of (although very COMMON) 1/4″ plug.
    A “stereo headphone” plug would be a typical TRS plug (either 1/4″ or 1/8″).
    In this case:
    TIP = Left Channel
    RING = Right Channel
    SLEEVE = Common/Ground
    But a TS (or Tip-Sleeve) 1/4″ plug is also very common (it is the standard “electric guitar cord” connector (It does not have the “ring” connection, but has a longer “sleeve” in that section of the plug.)
    In this case:
    TIP = Signal
    Sleeve = Shield/Ground
    So if the snake specifies “TRS” on its 1/4″ plugs, then you are good-to-go in EITHER case, as a TRS plug will work for either a TRS or TS setup.
  • Ronaldbeal
    May 11, 2005 at 1:26 pm
    You can also have TRS where one connector is both an input and output at the same time. This is common on some small mixers. I know Mackie mixers do this for inserts. I believe Tip is common, ring is send, sleeve is return. Additionally there are also balanced connectors (like XLR) that use tip as common, ring as signal+, and sleeve as signal-. Now that it is all clear as mud, hope it helps 😉
    Ronald Beal
    Lighting designer/programmer/operator/crewchief/technician
    TV and Rock&Roll
