Activity › Forums › Apple OS X › What is this?
What is this?
Posted by Alexander Kallas on May 31, 2011 at 1:15 pmAlexander Kallas replied 15 years, 2 months ago 2 Members · 4 Replies -
Jerry Jorgenson
June 2, 2011 at 1:12 pmThis isn’t a cookie, it’s a certificate warning. There was some problem with looking up the certificate. What it’s supposed to do is warn you about sites where the certificate isn’t to be trusted–which doesn’t mean the site is necessary bad, there are several reasons.
If you weren’t going to Facebook, then the site that you were at is fudging something.
Alexander Kallas
June 2, 2011 at 11:22 pm[Jerry Jorgenson] “his isn’t a cookie, it’s a certificate warning. There was some problem with looking up the certificate. What it’s supposed to do is warn you about sites where the certificate isn’t to be trusted–which doesn’t mean the site is necessary bad, there are several reasons.
“thanks Jerry, the weird thing is that I was shopping online at LLBean, should I contact them?
Surely they are reputable and would not fudge somethingCheers
Alexander -
Jerry Jorgenson
June 6, 2011 at 5:50 pmLLBean should be reputable, but it shouldn’t put up a FB certificate either. Although you can’t get a virus on a Mac, there is malware–typically trojans–that can fool you into installing something you’d probably rather not. I suggest downloading Sophos (it’s free) and have it run a scan. If you don’t want it on later, you can uninstall it.
https://www.sophos.com/en-us/products/free-tools/sophos-antivirus-for-mac-home-edition.aspx?utm_source=Magnet&utm_medium=Cross-link&utm_campaign=M-CL-Sitepromo -
Alexander Kallas
June 6, 2011 at 10:39 pmThanks Jerry, I’ll try it.
MacScan was OK but still showed the pop-up.Cheers
Alexander
