Activity Forums Apple Final Cut Pro Legacy What is this “Shift Fields Filter” upgrade?
  • What is this “Shift Fields Filter” upgrade?
    Posted by Chris Guevarra on July 19, 2010 at 6:42 pm
    Hi creative cows,
    I am currently testing out an upgrade from FCP 5.1.4 to FCP 6 in the middle of a documentary project that we’ve been working on for over 5 years. Upon trying to open up our project file with the new FCP 6 version, I got the prompt that asks me if I would like to apply the “Shift Fields Filter”.
    Exactly what will this do to the work we’ve already done and how will this effect us after upgrading?
    Chris Guevarra
    massmovementtv.blogspot.com
    Chris Guevarra replied 16 years, 1 month ago 2 Members · 2 Replies
  • Jeremy Garchow
    July 19, 2010 at 7:12 pm
    Wow, I vaguely remember that warning.
    I’d now say maybe. What format is your footage and timeline?
    Found this in the manual:
    Projects created in versions earlier than Final Cut Pro 6 must be updated when they contain incorrect or missing applications of the Shift Fields filter. For example, if you have a Final Cut Pro 5 project where you edited a DV PAL clip into a standard definition (SD) PAL sequence, Final Cut Pro 5 did not use the Shift Fields filter for combining DV and SD, so Final Cut Pro 7 must update your project to add Shift Fields filters to clips when necessary.
    Note: In cases where you removed a Shift Fields filter from an earlier Final Cut Pro project, Final Cut Pro 7 adds a new Shift Fields filter to any clip that needs one for proper playback.”
  • Chris Guevarra
    July 19, 2010 at 9:18 pm
    Wow, thanks alot for that find, Jeremy.
    Our footage was shot in 24p SD and cut on a SD NTSC Timeline. Any thoughts?
    Chris Guevarra
