Activity › Forums › Square Box CatDV › What is this icon in CatDV?
  • What is this icon in CatDV?
    Posted by Mark Underkofler on January 27, 2014 at 10:40 pm
    I get a weird icon when I use CatDV and attempt to drag a scene into Premiere Pro CC.
    Also, CatDV has a Export to Adobe Premiere CC, but nothing is sent to PP. I suspect it has something to do with a screwed up Exporter utility in Premiere.
    Any one have an answer?
    Thanks in advance,
    Mark Underkofler
    Dougal Matthews replied 12 years, 8 months ago 4 Members · 5 Replies
  • Robb Harriss
    January 27, 2014 at 11:20 pm
    “Stop, a rocket is striking”
    Non-linear: all the time and nothing but.
  • Dougal Matthews
    January 28, 2014 at 12:55 pm
    hi Mark
    we don’t support drag and drop with Adobe Premiere as we need to use some Adobe tools to send the information form catdv to premiere
    there are a few steps to get this working
    firstly in the catdv preferences under the export section you need to tell catdv which flavor of premiere your working with ( cs6 /cc ) as in the following screenshot
    to actually send files to premiere click on a file or shift select a group of files and then right click and select export as and then send to premiere cc ( this will show the option you chose in the set above so if you’ve selected CS6 it will say “send to premiere CS6” )as in the following screenshot
    the first time you try this you will be prompted to find the location of the “Adobe extendscript toolkit.app ( or .exe on windows) as in the following screenshot
    this can be found
     In Windows: {Program Files}\Adobe\Adobe Utilities – CC\ExtendScript Toolkit
    Cc.exe
     In Mac OS: In /Applications/Utilities/Adobe Utilities – CC/ExtendScript Toolkit
    CC.app,
    once you’ve done this Catdv will send the selected items to premiere
    next time you use export as >> send to premiere it will just work
    i hope this helps you get send to premiere working
    thank you Dougal
    Improvise Adapt and Overcome
  • Bryson Jones
    January 28, 2014 at 6:13 pm
    Dougal, thanks for the step by step man.
    bryson
    bryson “at” northshoreautomation.com
  • Mark Underkofler
    January 28, 2014 at 6:54 pm
    Works like a charm. It was the Adobe ExtendScript Toolkit that was causing the problem.
    Back to normal now. Thank you very much for your guidance.
    Mark
  • Dougal Matthews
    January 29, 2014 at 11:45 am
    no problem
    I’ve added this as a tutorial on our website its worth keeping an eye on the tutorials pages here
    https://www.squarebox.com/catdv-tutorials/
    were constantly adding new guides tips and tricks
    thank you dougal
