Activity › Forums › Adobe After Effects › What is this flowy painty technique?
  • What is this flowy painty technique?
    Posted by George Goodman on November 25, 2013 at 5:36 pm
    Weird post title, right? I’m curious to know how this person is getting such flowy transformations between shapes that leave the paint splatters behind it. Any insight would be greatly appreciated.
    https://vimeo.com/79902897
    George
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Jason Jantzen replied 12 years, 10 months ago 2 Members · 3 Replies
  • Jason Jantzen
    November 26, 2013 at 6:43 pm
    Two ways to animate that. I’m guessing the poofs of smoke are keyframed shape layers, but they could also just be frame by frame. I didn’t see the paint splatters you were talking about, but most likely just frame by frame keyframed, or hand drawn. A lot of animators like to incorporate a little frame by frame animation drawn in Photoshop, but you can also just animate each frame in AE to get a similar look. The big difference is frame rate, so you might animate every other frame instead of each one to get the right look (use hold frames).
    Jason Jantzen
    vimeo.com/jasonj
  • George Goodman
    November 26, 2013 at 7:38 pm
    Blast!
    I was hoping it wouldn’t be something that would take that kind of painstaking detail.
    I wondered if there would be a way to do it with a shape replicator and wiggle paths with time offsets
  • Jason Jantzen
    November 26, 2013 at 7:57 pm
    whenever I do it, it’s usually about 10-12 keyframes max. so like 10-12 stages of animation. think 12 fps old school flash animation days. that’ essentially the amount of detail you need here. the time it takes you to set up shape replicators and keyframe the offsets and such is about how long it takes to create each frame of that animation. Granted, there is a large degree of finesse required to make it smooth and beautiful. That’s the difference between “animator” and “AE artist”.
    Jason Jantzen
    vimeo.com/jasonj
