Activity Forums Avid Media Composer what is this effect?
  • what is this effect?
    Posted by Milton Hockman on May 23, 2007 at 2:13 am
    ON the show Dancing with the stars, they do a transition that looks like a motion blur on a clip. Similar to a woosh pan on a camera that is to fast for you to see what you are woosh panning by.
    but on the tv show’s effect it seems like it is using filters to create this effect. I can’t figure it out because it is more than just a motion blur it looks like the images in the clip are actually moving to the right.
    does anyone know how this is done or has seen it?\
    thanks.
    Milton Hockman replied 19 years, 3 months ago 2 Members · 6 Replies
  • Grinner Hester
    May 23, 2007 at 6:25 am
    you just publicly fessed up to watchin’ dancin’ with the stars.
    lol
    I’ve not seen this particualar effect. Mayeb echo in After Effects?
    You have a clip as a reference?
    I got great results today using two different camera angles. I’d quickly zoom in on the wide shot transitioning to the tight and vice versa. With a little motion blur and a hint of glow it turned out sweet. I use this same effect when I do obvious speed changes on a clip. Like a big boom shot at 100% then a bit of motin blur and/or glow to take it to 1000% then again to bring it back to real time.
    Very survivor.
  • Milton Hockman
    May 23, 2007 at 7:57 pm
    can you send me a clip of that effect you are doing? i’d love to see it.
  • Grinner Hester
    May 23, 2007 at 8:54 pm
    no prob. Hee is a quick clip of just soe resize effects usedto go from a wide shot to a tight then back:
    https://grinnerhester.com/monstereffect.wmv
    Looks like a snap zoom but it’s a 5 frame transition from one take to another. What you were discribing is done ver much the same way but often using motion effects as that go between instead of the fake zoom.
    heres what it looks like:
    You can see th two transitions. I have labled whats what in photoshop just to explain things a bit.
    You totally lose resolution whe zooming in/scaling up. The key here is doing it quick. As I mentioned before, a motion effect will help here if that gets too bad. I didn’t even use em in these two transitions. Basicly it’s just a three keyframe effect though. Nadda, to some blur back to nada type of deal.
    Also, any efect is helped greatly by some audio to go with it. Noe the sound effts clips under each transition. Can get redundant so use sparingy but helps a ton.
  • Milton Hockman
    May 24, 2007 at 2:29 am
    the clip had banding during the transition but i think i made it out.
    so basically you are using the wide shot and resizing up to the max percent to match your medium shot of the woman. then you are cutting to the medium shot of the woman? and at the same time using a little blur to make the resize not look pixelated?
  • Grinner Hester
    May 24, 2007 at 4:24 am
    exactly. great way to go from one shot to the other. they do not have to match perfectly. We’re talkin’ 5 frames tops for the whole transition.
  • Milton Hockman
    May 26, 2007 at 5:55 pm
    thanks for the tip grinner!
    i used this effect to blow up a MS to a CU. It looks a little pixelated at 150 percent, but it is passable.
    i used a zoom blur to make it look good and also a levels adjustment on the layer above. Looks sweet especially with a swoosh sound effect!
