Activity › Forums › Apple Final Cut Pro Legacy › What is the workflow converting 1080i 24p to true progressive 1080 24p
Edgar Metro replied 13 years, 9 months ago 6 Members · 19 Replies
Edgar Metro
December 19, 2012 at 7:06 pmThanks for getting back to me quickly Shane.
I won’t be dealing with any of the post work myself as I am just freelancer shooting a portion of this project. It is a set of interviews that are shot with different shooters.
The rest of the footage for the show was shot on an xd cam (a 350 I think) at 23.97fs.
I just want to make sure it matches up (both scanning and frame rate) to the xd cam so the editor won’t have any issues in the cutting room.
I think if I just shoot in 1080i 24pa it would be okay, right?
Sorry I’m not too familiar with workflows on the back end.
Would it be better to shoot in 720 so it will be true progressive… will the quality be an issue compared to the xd sony 350 -
Shane Ross
December 19, 2012 at 7:09 pmWell, there will be lots of issues getting to to work with the Sony. One being that the Panasonic shoots 1280×1080…a sort of SUPER anamorphic format…where the XDCAM might shoot 1440×1080 normal anamorphic, or might shoot full raster 1920×1080.
But, do what the client wants. Shoot 1080i 24pA, and inform them that your camera shoots a format that needs to have the pulldown removed in post, and if they use FCP, it happens when ingesting it. That is your best option for shooting 1080 23.98.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Edgar Metro
December 19, 2012 at 7:18 pmOne more thing shane…
If I record to 1080 24p or pa will it still be 100mbs -
Shane Ross
December 19, 2012 at 7:21 pmYes. DVCPRO HD is a 100mbs format. It will become slightly less when they remove the pulldown, only because frames are being removed…30 to 24. It’s a tricky thing. But DVCPRO HD is also known as DVCPRO 100…100mbps.
Shane
Little Frog Post
Edgar Metro
December 19, 2012 at 9:52 pmOne more question Shane if I may.
If I want the flatter image so they can do color correction, is the cinema v setting the best option for the hvx… -
Shane Ross
December 19, 2012 at 10:49 pmNow you are in territory I don’t know about. I’m an editor, not a camera guy. I disguise myself as one on occasion, but I’m not an advanced one.
Shane
Little Frog Post
Edgar Metro
December 19, 2012 at 10:52 pmNo worries, I just figured you would know because you’re very knowledgable. Thanks.
