Activity Forums Compression Techniques What is the transcoding unit for FFMPEG
  • What is the transcoding unit for FFMPEG
    Posted by Atish Kathpal on September 12, 2011 at 4:48 am
    Hi friends
    What is the transcoding unit for FFMEG? Is it a file or can we transcode a single file as user defined chunks of equal/variable size?
    Eg: Given a video: Austral.mpeg (10mins). Can I divide it into 10 chunks of 1 min each while transcoding, such that each 1min chunk is accessible once transcoding for it is over?
    Thanks and regards.
    Michael Rampe replied 14 years, 11 months ago 2 Members · 1 Reply
  • Michael Rampe
    September 22, 2011 at 8:15 pm
    [atish kathpal] ” can we transcode a single file as user defined chunks of equal/variable size?”
    yes but you will have to run one command for each chunk.
    -t is a time offset
    specified seconds or hh:mm:ss[.xxx]
    -ss is the length to encode
    This option behaves differently if put before or after the -i [input]
    Before:seeks to nearest I frame before converting (fast but inaccurate)
    After:seeks through every frame until target is reached (slow but accurate)
    So:
    first chunk: -t 0 -ss 60
    second chunk: -t 60 -ss 60
    third chunk: -t 120 -ss 60
    …..etc.
    Michael
