Activity › Forums › Adobe Premiere Pro › What is the preferred IO for Premiere Pro?
Posted by Erik Naso on July 12, 2011 at 3:47 pmI have a AJA Kona LHe and LHi in two systems that run FCP, but wanted to see what products are preferred or work best for IO in Premiere Pro CS5.5.
Blog https://www.eriknaso.com
My Vimeo Page https://vimeo.com/user626030
Follow me on Twitter @ErikNasoJeff Brown replied 15 years, 1 month ago 8 Members · 13 Replies -
Deleted User
July 12, 2011 at 4:31 pmHello Erik,
Either will work very well in Premiere pro.
Leo
Erik Naso
July 12, 2011 at 4:39 pmI found the relationship with AJA and Premiere is not as solid as with FCP7. After trying both out for just playback to a broadcast monitor it seems its not as peppy with Ppro cs5.5. Some lag when playing timeline, audio drops sometimes. Little annoying stuff. 🙂
Follow me on Twitter @ErikNaso -
Shane Ross
July 12, 2011 at 5:01 pmWell, the Matrox Axio line was the preferred option not long ago…but on the PC side. And now the Axio line is gone, replaced by the MXO2. I have that, and it seems to work OK. But I haven’t dug deep into Premiere yet.
Shane
Read my blog, Little Frog in High Def -
Miro Segura
July 12, 2011 at 5:07 pmErik,
I have the same experience. I was getting audio drop outs during playback, so I experimented a little.In my Mac system preferences I set the audio out to “Headphones (Headphone port)”.
Went back to PPro CS 5.5 (using the AJA settings) and played the timeline and no more audio drops outs! Not sure why this is, but I do agree with you that the AJA drivers are buggy and not as good as the ones for FCP7.
For example, when I scrub the timeline not using the KONA 3, it scrubs smoothly and the timeline is very snappy and responsive. When I use the KONA 3 board, it seems to slow down the timeline, and when I scrub the timeline it just skips to frames and does not give me smooth playback. This is problematic when trying to do fine cuts.
Miro
John Pale
July 12, 2011 at 5:14 pmCurrently testing it with Blackmagic Decklink Studio. Was nearly unusable until the latest beta driver was released. Now seems very good…will be pushing it harder this week.
Tom Daigon
July 12, 2011 at 5:31 pmHey Kona owners. AA recently released new Kona drivers 9.0.3 and Adobe plugins 9.0.1. Make sure you are up to date for the best performance.
https://www.aja.com/support/konaNEW/kona-3-3x.phpTom Daigon
Avid DS / PrP / After Effects Editor
http://www.hdshotsandcuts.com -
Tim Kolb
July 12, 2011 at 5:40 pmI think part of the issue may be platform differences as well…Windows vs Mac as well as the difference in drivers for FCP which have only needed some bug fixes over the last four years vs PPro, which has taken such massive steps in the last four years that the hardware drivers have had to make large changes…multiple times.
Also I suspect it’s easier to run a driver for a strictly QT ecosystem than for PPro, which has had to “work around” QT for the last two releases to accommodate all the native format support, etc.
As I’ve said in other threads, I think FCP users in migration need to remember that the CS5 major release is just over a year old and the 5.5 upgrade is a couple months. Third party developers (particularly for solid SDI I/O)are faced with a pretty stiff task.
I realize that doesn’t solve today’s problem, but I think it’s important if you choose to compare third party hardware support…to go back to a similar moment in FCP’s release cycle to evaluate where third party vendors were with feature sets and dependability.
It will get there.
As a long time PPro user, I’d also say that most third party vendors have been spending most of their time over the last 5 years focusing on FCP.
Premiere Pro was a bit of a second-class citizen for most of these manufacturers. (look at how many PPro stations were in these booths at NAB vs FCP…even in 2011!)
Now that FCP users are switching, maybe we can get the attention that Premiere Pro needs to bring third party hardware support up to the level of legacy Final Cut.
TimK,
Director, Consultant
Kolb Productions,Adobe Certified Instructor
Erik Naso
July 12, 2011 at 5:50 pm[Tom Daigon] “Hey Kona owners. AA recently released new Kona drivers 9.0.3 and Adobe plugins 9.0.1. Make sure you are up to date for the best performance.
https://www.aja.com/support/konaNEW/kona-3-3x.php“That’s what I’m running. Much better but not there yet.
Erik Naso
July 12, 2011 at 5:53 pm[Tim Kolb] “Now that FCP users are switching, maybe we can get the attention that Premiere Pro needs to bring third party hardware support up to the level of legacy Final Cut.”
Amen!
