Activity › Forums › Adobe After Effects › What is the outro called in this video?
  • John Cuevas
    November 5, 2012 at 12:51 pm
    Not sure about the template(and I wouldn’t pay for it anyway, that’s really simple). You could create that with a wood background and an animated mask(if you don’t have any water/ink matted footage)
    Take wood background and place as lower layer. Duplicate wood background and add a color effect to make it look wet. Add your text layer that you want to appear. Now take the wet wood and text and precomp them(shift + cntl + c).
    In your main comp add a solid above your precomped text wood layer. Turn the opacity(T) to 50%. Now using the pen tool draw a rough mask around text layer that should be about where the water spills out. I would add the effect Stylize > Roughen Edges. Now you could just scale the layer to create the water spilling out, but I would animate the mask some as it scales up and play with the evolution of the roughen edges effect also.
    Once you create a solid that animates like spilled water, change the opacity back to 100% and change the track matte of your wood/text layer to Alpha.
    You can find free ink bleeds by doing a google search. Or buy them at video copilot in the riot gear package.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
