Activity Forums Apple Final Cut Pro Legacy What is the longest amount you should digitize ?
  • What is the longest amount you should digitize ?
    Posted by Chris Collins on March 26, 2008 at 8:14 pm
    Using mini dv tapes, digitizing to a Lacie External drive, how long can a clip be captured for safely?
    -chris
    (can you tell i got caught up on a project that there’s no AE and i’m trying to figure out all the stuff i long since forgot when i stopped A.E’ing? But, good to get back to my roots…arrgh…)
    Final Cut 5.1.4 on a G5
    Rennie Klymyk replied 18 years, 5 months ago 6 Members · 6 Replies
  • Walter Biscardi
    March 26, 2008 at 8:22 pm
    DV clips are very small, you can digitize as long as you like.
    But keep in mind, long clips are not the ideal way to edit. Logging the individual clips and capturing that way are always preferred to long rolls. Unless it’s just a talking head and you need it all in one continuous take.
    Also, any hard drive will drop speed at 75% full, then progressively get slower as you capture.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Shane Ross
    March 26, 2008 at 8:46 pm
    If I capture in chunks, I capture in 10-15 min chunks. So if a capture fails, I only have to capture 10 min, instead of it failing after nearly an hour and having to start all over again. Plus if you lose that media, it is only a 10 min capture.
    The longest I go is 30 min…typically with interviews, and if the camera load is actually 30 min. Otherwise I break it up…at points where questions are asked.
    Shane
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.LFHD.net
    Read my blog!
  • Arnie Schlissel
    March 26, 2008 at 11:30 pm
    Assuming your drives can handle it, there’s no reason you couldn’t capture whole tapes. I’ve captured entire 3 hour DVCam tapes in one shot.
    Now, that said, that doesn’t mean that’s necessarily a smart thing to do… If you need to send it to Soundtrack, or run a Smooth Cam filter on it, you’ve got to do it to the whole tape.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Uli Plank
    March 27, 2008 at 7:00 am
    I’d advise to use in and out points even on whole tapes instead of direct capture, though.
    I’ve seen sound audio sync issues when not doing this.
    Regards,
    Uli
    Director of the Institute of Media Research (IMF) at Braunschweig University of Arts
  • Arnie Schlissel
    March 27, 2008 at 2:38 pm
    [Uli Plank] “I’d advise to use in and out points even on whole tapes instead of direct capture, though.”
    Absolutely! I think that a lot of the problems people have with media in FCP is due to people not logging their tapes.
    Arnie
  • Rennie Klymyk
    March 27, 2008 at 3:02 pm
    Yes, mini dv doesn’t lock audio like dvcam does. Even though it is supposed to remain with in +- 17 frames during recording it can and does drift more on long captures.
    “everything is broken” ……Bob Dylan
