Activity Forums Apple Final Cut Pro Legacy What is the highest version of Quicktime and iTunes I should use with FCP 5?
  • What is the highest version of Quicktime and iTunes I should use with FCP 5?
    Posted by Ian Dillon on October 23, 2009 at 1:44 am
    What is the highest version of Quicktime and iTunes I should use with FCP 5? I know if I go to high on either I will run into problems. What are the magic numbers? Someone mentioned checking version tracker, but I don’t think it gives that type of info. Somewhere there must be a post about this.
    HELP!
    Playroom Creative
    http://www.playroomcreative.com
    Rafael Amador replied 16 years, 10 months ago 2 Members · 1 Reply
  • Rafael Amador
    October 23, 2009 at 2:03 am
    [Ian Dillon] “Someone mentioned checking version tracker, but I don’t think it gives that type of info. Somewhere there must be a post about this.”
    Yes. This information is available.
    Look for it and try to learn from the original source.
    In a post you hardly will find the same info.
    rafael
    http://www.nagavideo.com
