Activity › Forums › Panasonic Cameras › What is the hdx-900 truth ?
  • What is the hdx-900 truth ?
    Posted by Peter Steinman on July 16, 2006 at 8:28 am
    Panasonic guys say, “Don’t worry. The Varicam will not be replaced for 3 years!”
    Owner’s go, “So what makes the 900 worse then the Varicam ?”
    Panasonic, “Umh.. we crippled the software so they can’t change certain camera functions”
    Owner’s. ” So is anything else besides software lockouts different?”
    Panasonic, ” umm ya, umm umm don’t tell so and so but, the part X might not be the best coming out of area Y. It may be exactly the same but, hey it might not be. Not that I actually can be quoted as saying one way or the other.”
    Panasonic, “Don’t worry”
    Peter Steinman replied 20 years, 2 months ago 5 Members · 5 Replies
  • Tony
    July 16, 2006 at 8:21 pm
    Utimately the rental facilties and client demands will make the final decision as to which camera (Panasonic, Sony,GV,Ikegami,JVC, etc etc survives or goes to the wayside.
    In short screw the manufacturer’s hype and BS and listen quite closely to what your repeat clients, rental facilties or vendors you do constant business are talking about.
    Be sure to read between the lines to filter out the hype and find the truth.
    Tony Salgado
  • Robin Probyn
    July 17, 2006 at 2:27 pm
    Hi there
    I know I could look it up on their site,but may have to wade through the hype.Can someone give me a quick ish run down on this camera.Who can put all the tech stuff down in normal-ish speak and the real pro,s and con,s
  • Thomas Kaufman
    July 18, 2006 at 12:21 pm
    Unless I’m mistaken, the CCD array of the Varicam would cost about $30,000 to replace.
    The price of the HDX900 is under $30,000.
    What does that tell you?
    Long live the COW!
    Thomas Kaufman, DP
    Washington, DC
  • Pat Mcgowan
    July 18, 2006 at 2:18 pm
    It should tell us that the R and D for the Varicam has been paid for and mass manufacturing has brought economies of scale to consumers.
    Or am I that naive?
  • Peter Steinman
    July 19, 2006 at 5:51 am
    It is already known the ccd’s are exactly the same between the two. Panasonic sales guys do a wink wink nudge nudge thing about the prism block. I sort of doubt it would be worth it to develop a seperate optical block to save money. I’d guess it’s either a Varicam block or its a sdx block if the two are even different.
    I was looking at the specs for the 900 and it mentioned “Optical System: F1.4 Prism System” Try as I might I can find a optical system spec for the varicam. Anyone know ?
