Activity › Forums › Apple Final Cut Pro Legacy › What is the “go to playhead” command?
Posted by Keith Mann on May 13, 2005 at 2:32 pmI’ve searched the manual and just can’t seem to find the keyboad command to:
“go to playhead”
and
“zoom into playhead”
Thanks in advance
Mike Stanley replied 14 years, 8 months ago 8 Members · 8 Replies -
John Fishback
May 13, 2005 at 2:44 pmIf the playhead plays off the end of the sequence you have to scroll to follow it. When you stop playing, the sequence will snap to the playhead. Ctrl + or – or Command + or – zoom in and out.
John
Dual 2.5 G5 4 gigs RAM OS 10.3.8 QT6.5.2
Cinema 23 Radeon 9800
FCP4.5 DVDSP 3.0.2
Huge U-320R 1TB Raid 3 firmware ENG12.BIN
ATTO UL4D driver 3.20
AJA IO driver 1.3.1 firmware v21-26
SonicStudio HD DAW, Yamaha DM1000, Genelec Monitors -
Nick Meyers
May 13, 2005 at 2:53 pmah yes.. zoom to playhead!
a long cherished dream of all fcp editors!
but in reality, you dont zoom to playhead, you can only zoom to selection.
one of the many comands in FCP where selection takes precedent.
but once youve zoomed into a selected clip, and you want to egt to hte playhead, it’s really simple:
you just nuge the playghead forward one frame, and FCP wakes up to itself, and takes you to it.
i use the left /right arrows to nudge/move a frame at a time.
if the frame you plarked on was crucial, then go left arrow, right arrow, to jog FCP into place, and to wind up back on the frame.oh, yes, you should de-select, too, before you go to far.
That;s Shift Apple A ( the opposite of apple A for select all)
(i re-map to Apple D for De-select)i do this so often, ive kind of forgotten about wanting “zoom to playhead”
cheers,
nick -
Tom Matthies
May 13, 2005 at 4:57 pmIf you don’t have ANY clips selected (or transitions) and you use the zoom command (I use CMD+ or CMD-) it will center the playhead to the middle of the sequence window and zoom in/out from there. You should be able to zoom straight into a clip as far as the system will go and then come back out again while the playhead stays centered in the sequence window.
Tom -
Bill
May 13, 2005 at 6:21 pmjust for refernce command +/- works in whatever window you are in at the time adn Option +/- always works with your sequence.
Martin Baker
May 13, 2005 at 8:28 pmand just for the record, using the zoom slider in the Timeline window will always zoom into the playhead position even when clips or transitions are selected.
Martin
Digital Heaven, London UK
________________________________________
Ten Final Cut Plug-ins for just $10 each -
Steve Regian
May 14, 2005 at 2:08 amIf, like I, you would like to see a zoom to playhead key shortcut, regardless of whether or not anything is selected, be sure to leave feedback at Apple.
Mike Stanley
December 8, 2011 at 12:40 amAMEN! I’m struggling to find capability in FCP X. Honestly, if they made this one simple function work, I think a lot of people wouldn’t dismiss the program so much. It’s almost IMPOSSIBLE to navigate the timeline in FCP X. Zooming is like being in a circus. One minute you’re on your clip, the next you’re at the end of your timeline. It’s ridiculous and they need to change it.
