Activity › Forums › Adobe InDesign › what is the equivalent of masking in inDesign
Posted by Dawud Ali on June 2, 2011 at 6:30 pmHi guys thanks for your time
what is the equivalent of masking in inDesign so to have more control when cropping placed images?
i try using the pen tool i can’t figure how to select points individually? using command or alt or shift or a special button while selecting a point
thanks for your time in advance
Mark Williams replied 13 years, 2 months ago 4 Members · 6 Replies -
Ron Lindeboom
June 5, 2011 at 5:02 pmPersonally, I do all of my masking in Photoshop and then bring the file into InDesign. I am just a lot more comfortable manipulating images in PS and find that it’s much more powerful.
I might be missing the point of your question and if so, my apologies. If I am, hopefully someone else will jump in and more directly respond to your question.
Best regards,
Ronald Lindeboom
CEO, Creative COW LLC
Publisher, Creative COW MagazineCreativity is a process wherein the student and the teacher are located in the same individual.
“Incompetence has never prevented me from plunging in with enthusiasm.” – Woody Allen
Dawud Ali
June 5, 2011 at 10:20 pmThat’s alright, use what u already know right. and ps does have capable tools. sometimes you may want to create a quick outline or crop an images directly, instead of using other applications.
i think what i found is you can add points using the pen tool and then use the white arrow, shift select single point and manipulate.
thanks
Ron Lindeboom
June 5, 2011 at 10:29 pmI like to have more control than I can get using some of InDesign’s masking tools. But in the end, it is use whatever tool works for you. This has never been a one-size-fits-all world.
If you get satisfactory results, Dawud, I would love to see what you come up with. I always like to learn new things.
Best regards,
Ronald Lindeboom
Terry Mikkelsen
June 8, 2011 at 8:34 pmFor your TRUELY simple stuff…
Click the image with your “Selection Tool” (v)
Now select the “Add Anchor Point Tool” (=)
Click on the image border to add some points
Finally, use your “Direct Selection Tool” (a) and move to points to crop it out.For the little bit more involved, you can try the Detect Edges. (Object>Clipping Path>Options…) You can get a rough outline with it and then clean it up with the Direct Selection Tool.
But, as Ron says, the best tool for the job is Photoshop. Indy can do well though for those quick and sloppy jobs.
Tech-T Productions
http://www.technical-t.com -
Dawud Ali
June 9, 2011 at 7:30 pmthanks for sharing those tips especially the last one, should come in handy
thanks again
Mark Williams
July 8, 2013 at 2:40 pmYou basically just edit the frames with the pen tool and the direct selection tool
