what is the differnce between channel A and B?
Posted by Jessica Robbins on September 9, 2008 at 6:32 pmI am looking to by a dual wireless lav system for my ag-hvx200. What is the difference between channel A and B systems?
Does the panasonic ag-hvx200 take both systems or just one?
JessicaDavid C jones replied 18 years ago 4 Members · 3 Replies -
Steve Wargo
September 10, 2008 at 3:58 amWe’re lost Jessica. Where are you getting the A-B info?
You’ll either need a pair of systems or you can get a single system like a Zaxcom or maybe Azden makes something less expensive.
https://www.azdencorp.com/shop/customer/product.php?productid=93806&cat=0&page=Steve Wargo
Tempe, Arizona
It’s a dry heat!Sony HDCAM F-900 & HDW-2000/1 deck
5 Final Cut (not quite PRO) systems
Sony HVR-M25 HDV deck
2-Sony EX-1 HD . -
Rob Neidig
September 10, 2008 at 3:24 pmIf you are referring to the Sennheiser G2 wireless systems, the difference is in the range of frequencies. The A range is 518 -550MHz, while the B is 630 – 662MHz. You want a range that will not have interference from your local UHF TV stations. You should check out the frequency selection chart on Sennheiser’s web site to get an idea which might be better for your area. Link below:
https://www.sennheiserusa.com/newsite/mat_dev/frequencyfinder/Freqfinder-ew.asp
Otherwise the A and B systems are exactly the same. Have fun!
Rob
Rob Neidig
R&R Media Productions
Eugene, Oregon -
David C jones
September 10, 2008 at 7:08 pmHi Jessica
The HVX-200 (or any camera for that matter) will work with any wireless system. However, as far as I know, Sennheiser doesn’t make a dual channel wireless system (as of yet). Your choices are the Audio Technica 1800, Lectrosonics SR, Sony DWRS01/WWR862B and Zaxcom.
