Activity Forums Adobe After Effects What is the difference between X-spline and bezier layer in Mocha?
  • What is the difference between X-spline and bezier layer in Mocha?
    Posted by Guillaume Jaecques on June 12, 2017 at 8:19 am
    I’m trying to figure out what the benefits and differences are between X-spline and bezier layers in Mocha, but just can’t figure out when to use what. Somebody that can give a quick idea of the difference of these two? It would help me a lot!
    Roei Tzoref replied 9 years, 2 months ago 3 Members · 2 Replies
  • Mark Whitney
    June 12, 2017 at 4:36 pm
    Easiest way to understand them is to simply make one of each and play around with the handles.
    The X-splines will be easier to use in most cases. The handles will always mirror each other. Since one is most often just making a rough shape in Mocha, that sort of control is quicker to work with.
    Bezier’s can “break” the curve with independent handle control. If you’re trying to make a crescent moon shape for example, then that’s what you’d use.
  • Roei Tzoref
    June 12, 2017 at 5:38 pm
    As a rule of thumb: X for organic shapes and most of your tracking needs, B for percise geometric Rotoscoping.
    Roei Tzoref
    After Effects Artist & Instructor
    ♫ Ae Blues Tutorials
