Activity Forums Blackmagic Design What is the difference between Uncompressed-10 bit 4:2:2 and Blackmagic 10bit (DV10)
  • What is the difference between Uncompressed-10 bit 4:2:2 and Blackmagic 10bit (DV10)
    Posted by Andreas Karoliussen on January 3, 2007 at 7:52 pm
    I’m working in FCP 5.1.2 with a Blackmagic card and I’m now upressing some of my clips that are going to shake and maya for bluescreen, graphics and compossiting with 3-D animations.
    The material I’m upressing now is shot DVCPRO50 PAL
    So my question is which compressor should i use?
    When I chose the capture setting: “Blackmagic 10 bit” in FCP the “Uncompressed” compressor is default, however here is a compressor called “Blackmagic 10bit (DV10)”
    so what is the difference between Uncompressed-10 bit 4:2:2 and Blackmagic 10bit (DV10)?
    Or should I use DVCPRO PAL 50 (since that’s my recording resolution) or should i use Black magic RGB 10 bit?
    I also have digibeta and DV recordings, but i recon its best to upress all different formats with one codec/compressor.
    Andreas Karoliussen replied 19 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
