Activity Forums Adobe After Effects What is the difference between Multiplexing: DVD and Mulitplexing: None
  • What is the difference between Multiplexing: DVD and Mulitplexing: None
    Posted by Chad Ramos on March 25, 2010 at 4:54 pm
    Hello,
    I was wondering what the difference between DVD an None are when setting the Multiplexer of a MPEG2-DVD export.
    REgards
    Chad
    Nathan Hall replied 16 years, 5 months ago 2 Members · 6 Replies
  • Chad Ramos
    March 25, 2010 at 5:41 pm
    So you are suggesting I should export via “Video for Windows” and use a third party encoder?
    Regards
    Chad
  • Chad Ramos
    March 25, 2010 at 6:11 pm
    I am sorry…I ment using the render queue. I do believe there is a mix up. The default format for the render queue on a windows platform is “Video For Windows”. Which shows up as “No Compressiong” on “Output Module Settings”. I just did this to a 10 min composition and it rendered a .avi that is 48+ gigs. I believe this seems correct considering the size of the file. Does this seem correct to you?
    Regards
    Chad
  • Chad Ramos
    March 25, 2010 at 6:25 pm
    As stated in my above post the duration of the video is 10 mins. The render matches up to the same duration. Which only leads to me to believe that 48.1 gb file is the proper “uncompressed” file. Especially considering when rendering it stated “No Compression” and “lossless”. None the less thanks for the help. I will take a look at a few other resources to help further verify.
    Regards
    Chad
  • Nathan Hall
    March 26, 2010 at 7:58 am
    Add to render queue > output module > format = quicktime > format options = animation > ok > render
    Then compress it in ame if you have cs4.
    As long as you have qt installed on your pc you should have that option.
    That is the best solution for what you’re wanting.
    https://www.anchormedistudio.com
  • Chad Ramos
    March 26, 2010 at 2:06 pm
    I don’t know what this means but your suggested method actually yeiled a smaller file then my early course of action.
    Quicktime Animation = 37.0 gb
    “Video for Windows” = 48.1 gb
    So I assume the “Video for Windows” setting (which exports what I believe is a uncompressed avi) would still be the better choice.
    What do you think.
    Regards
    Chad
  • Nathan Hall
    March 26, 2010 at 5:16 pm
    Animation is a lossless codec when set to 100%. I suggested it because it can support alpha channels (if millions of colors+ is selected), it’s 4:4:4, it’s cross platform and any setup with Quicktime installed will be able to work with the file.
    Unless you have a workflow issue that requires avi I would stick with the QT format.
