Activity › Forums › Adobe After Effects › What is the difference between an objects path position, object transform position and transform position?
  • What is the difference between an objects path position, object transform position and transform position?
    Posted by Blake Warner on September 4, 2014 at 7:31 pm
    I am new to After Effects and am scratching my head as to why there are three different options for changing settings like position for example. I was hoping someone could clarify the difference between the three. So far, I can’t tell that there is any as I can change the position of an object from “path”, “transform path”, or “transform” and the position changes the same.
    Walter Soyka replied 12 years ago 2 Members · 1 Reply
  • Walter Soyka
    September 5, 2014 at 12:38 am
    All layers in Ae have a few intrinsic transform properties, including position. Animating this property will move the entire layer.
    All paths in Ae define points in a space relative to the layer they’re on. You can animate paths, including transforming their position, without moving the layer. You can have multiple different paths on a layer and animate them separately.
    On shape layers, paths and other content can be organized into groups. A group may transformed; any transformations applied to the group will affect all the paths within the group, but again will not affect the actual position of the layer.
    So essentially, there is a hierarchy: first the layer, then groups, then paths within the group. Transformations are possible at any level and affect everything downstream, but nothing upstream.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
