Activity Forums Adobe After Effects Expressions What is the correct syntax for file path names in expressions?
  • What is the correct syntax for file path names in expressions?
    Posted by Dave Morales on August 20, 2017 at 12:02 am
    After Effects CC 2017 on Windows 10
    I am trying to to a simple variable import from an external text file to populate a text layer with this basic expression in the “Source Text” field:
    $.evalFile(“\Users\Dave\Desktop\RealEstate\roomnames.txt”);
    text1
    I get a “File not found” error.
    If I use forward slashes, I get a “Syntax” Error.
    This seems like it should be simple but I have spent hours looking for a solution and can not find anything that works.
    $.evalFile("\Users\Dave\Desktop\RealEstate\roomnames.txt");
    text1
    Andrei Popa replied 9 years ago 2 Members · 1 Reply
  • Andrei Popa
    August 29, 2017 at 6:50 am
    The correct path would be
    $.evalFile("/Users/Dave/Desktop/RealEstate/roomnames.txt");
    Andrei
