Activity Forums Adobe After Effects What is the command for snapping a image into the comp. frame?
  • What is the command for snapping a image into the comp. frame?
    Posted by David Del on September 1, 2006 at 6:45 pm
    I am resizing some images in AE 6.5 and I am doing it by eye trying to size them the exact size of the comp. Is there a command for this or a hotkey?
    David Del replied 19 years, 8 months ago 3 Members · 3 Replies
  • Aanarav Sareen
    September 1, 2006 at 6:48 pm
    1. Import your images
    2. Place your images into a composition of the desired size (for example: NTSC DV)
    3. Right click on the layer > fit to comp height or fit to comp width.
    Aanarav Sareen
    premiere@asvideoproductions.com
  • Anthony Dupsta
    September 1, 2006 at 9:22 pm
    Try this on windows
    ctr alt F
  • David Del
    September 1, 2006 at 11:07 pm
    Thank for you that, unfortunately, it seems to screw up my keyframes when using the camera, but at least I know it is there.
