Activity › Forums › Adobe Premiere Pro › What is the best way to speed up GH4 footage shot in a variable frame rate (36fps) to real time 24fps?
Posted by Alicia Agramonte on May 19, 2017 at 8:46 pmHi Guys. I filmed a two scenes on my GH4 but made the rookie mistake of not understanding the variable frame rate tool. So all of my footage was shot in 36fps. Basically:
Frame Rate: 36fps
Slow/ Fast Effect: 67%
Rec Frame Rate: 24
Am I just screwed here or is there any way to speed this footage up to real time? Perhaps a better way that speed/duration? I’m low key hyperventilating…Alicia Agramonte replied 9 years, 3 months ago 3 Members · 5 Replies -
Dan Powers
May 19, 2017 at 9:27 pmAfter Effects is your best bet to restore it to it’s proper speed. The good news is that you have more frames than you need. The opposite is much worse.
1 in 3 frames is going to be kicked out so I would play with the various frame interpolation modes. Blend, Mix, Pixel motion etc.
Play with nesting the clip and time stretching, then adjust your quality.
If you have a short clip that I could download I could test some settings for you. -
Alicia Agramonte
May 19, 2017 at 9:43 pmWould really appreciate that. Here’s a link to a small file! https://www.dropbox.com/s/5ng9f9qhnhdqg5v/P1080822.MOV?dl=0
I will say I did try speed duration to 150% (1.5x) and after rendering it doesn’t look bad but I want to make sure that doesn’t kill me later when exporting. Would hate for this to come out choppy.
Andreas Kiel
May 22, 2017 at 11:45 amIf you do 1.5 time scale you will get a slomo.
The other way would be merging frames like said above. Merge 2 with 3, 5 with 6 etc.
I personally wouldn’t drop frames – like every third one.– Andreas
Spherico
https://www.spherico.com/filmtools“He who fights with monsters should be careful lest he thereby
become a monster. And if thou gaze long into an abyss, the abyss will
also gaze into thee.” – Friedrich Nietzsche, Beyond Good and Evil -
Dan Powers
May 22, 2017 at 2:25 pmYour clip has subjects mostly walking toward camera, so there isnt much information lost in the kicked out frames. If you have action crossing fully across frame, you will notice it more.
I tried two different processes, both in After Effects, but same can be done in Premiere.
One, 23.976 Timeline, footage interpreted to 36fps.
Other was 23.976 timeline with footage interpreted to 23.976 and time stretched by 66.734% and tried the different interpolation methods. Again on this clip, there wasnt much difference.
But 1.5X (75% time stretch equivalent) speed is a no go. That is not an accurate speed correction. You are going to have to do a 66.734Good luck.
Alicia Agramonte
May 22, 2017 at 5:56 pmThank you!!! I ended up doing 67% over the weekend and after a bit of a trial and error, the sound just started linking with all videos easily (though manually. Shooting in VFR is a nightmare if you have to match up external sound). Not quite sure what the difference is between VFR and just shooting up to a different frame rate but I guess thats a question for another thread. Thanks guys!
