Activity › Forums › Avid Media Composer › What is the best way to export HD 1080p?
  • What is the best way to export HD 1080p?
    Posted by Ori Burg on September 6, 2010 at 6:26 pm
    What is the best way to export an hd 1080p footage for making a dvd from it?
    There is better format to export to after effects than using quicktime refference?
    And which dvd app should i use? Im working with avid on mac if
    Michael Phillips replied 16 years ago 3 Members · 4 Replies
  • Michael Phillips
    September 6, 2010 at 8:47 pm
    Qt reference works great. Links to the original media used in the project and does not take up any additional drive space in doing so. The QT reference can be used in most if not all DVD encoders be it for SD or HD or directly in the authoring program.
    You won’t get better quality if you go to another format, even uncompressed – just additional time and storage.
    Michael
    Michael Phillips
  • Ori Burg
    September 7, 2010 at 12:03 pm
    What dvd authoring application do you recommend?
  • Ed Cilley
    September 7, 2010 at 10:24 pm
    Yes, QT Reference is great, but you can’t use QT Reference with Long GOP formats (HDV). You need to export a full QT or an M2T file.
    I personally use Avid to cut on my Mac, then use Compressor and DVD Studio Pro. But, Adobe Encore is really nice with some features (like making a Flash file) that are really nice.
    Ed
    Avid and FCP Preditor
    _________________________________________________
    Anything worth doing at all, is worth doing well.
    – Philip Dormer Stanhope, Earl of Chesterfield
  • Michael Phillips
    September 7, 2010 at 10:28 pm
    If using Long GOP, you can transcode sequence to DNxHD first, then do a QuickTime reference. It may be faster. I do like authoring in Encore myself, but I encode using Rhozet Carbon Coder.
    Michael
    Michael Phillips
