Activity Forums Avid Media Composer What is the best way to export for BluRay and DVD
  • What is the best way to export for BluRay and DVD
    Posted by Dave Edwards on June 16, 2013 at 8:39 am
    I’m new to Avid and at present I’m exporting projects as Quicktime – “high” quality, not single pass, and then importing this into DVD Architect to make DVD or BluRay discs. Is this a good way to proceed or is there a better approach which will optimise picture quality?
    Dave Edwards replied 13 years, 2 months ago 2 Members · 2 Replies
  • Job Ter burg
    June 16, 2013 at 10:09 am
    Rule of thumb: do not use the Avid to convert upon export, but rathe do a Same As Source export from Avid. This simply keeps codec and resolution as they are, just rewrapping your stuff into a QT container.
    Then you must find out which luma level range your BD or DVD encoding application is expecting.
    See:
    https://www.jobterburg.nl/Publications/601_709_RGB.pdf
    for an explanation of the import/export settings in Avid MC regarding luma level range (16-235 versus 0-255).
  • Dave Edwards
    June 16, 2013 at 10:29 am
    Thanks, Job,- I’ll look at this.
