Activity › Forums › Adobe Premiere Pro › What is the best way to down convert?
Posted by Joe Cinquina on October 5, 2007 at 3:13 amIs it better to down convert in Premiere or straight from the HDV Camera?
Also, how is this accomplished?
What project setting do you use? (I am assuming SD 16X9)Thanks again.
I’m learning….
Best Regards,
Joe
Perry Cheng replied 18 years, 10 months ago 3 Members · 5 Replies -
Blast1
October 5, 2007 at 9:15 amDown convert in the cam, read the cam’s manual it will give you the DV out format options
Perry Cheng
October 5, 2007 at 6:02 pmThat’s one option, but if you are going to edit, I will capture as HDV first, edit, and then downconvert using DVD Presets or whatever (depends on your audience).
Perry
Joe Cinquina
October 5, 2007 at 6:51 pmPerry – Thank you for your reply. I just have one question, why would I edit first? I thouight it would be better to edit in SD and use all the normal tools and performance and compatibility would be better.
Thanks.
Joe
Perry Cheng
October 6, 2007 at 9:53 amJoe,
If you computer is fast enough, editing in HD allows you to have extra pixels room as well as not loosing the quality of re-renderings.I have read elsewhere, yes, you can take the Camcorder down to SD and let it hardware convert for you from HDV to DV first before you bring it to your computer, however, the PQ is not as good.
Perry
Perry Cheng
October 18, 2007 at 11:02 pmJust want to clarify, Joe, you want to create a SD presets, import the HD footage into it and the HDV will be imported as bigger than the SD presets and thus you can cut off some pixels that can create interesting things. Then, export that to DVD.
Perry
