Activity › Forums › Apple Final Cut Pro Legacy › What is the best way to convert HDV to HDCAM?
Posted by Craig05 on March 28, 2006 at 7:10 amI would like to know the best way to convert 50 minutes of footage from 1080i HDV to 1080i HDCAM. I currently use Final Cut Pro 5
Michael Gissing replied 20 years, 5 months ago 4 Members · 4 Replies -
Joseph Bradley
March 28, 2006 at 7:36 pmIf you create a new sequence, set the settings for HD1080i60, drag the HDV footage into it and render, that should create the changes you need.
Walter Biscardi
March 28, 2006 at 7:52 pmThe best workflow is to come component out of an HDV deck and capture directly through HD card at the 8 or 10bit 1080i. I would use an AJA HD Component to HD-SDI converter and connect that to a Kona 2 or Kona 3 system.
That will yield the cleanest image from HDV material.
Walter Biscardi, Jr.
https://www.biscardicreative.comDirector, “The Rough Cut”
https://www.theroughcutmovie.comNow Posting “Good Eats” in HD for the Food Network
Craig05
March 28, 2006 at 8:57 pmThanks guys for the info…I will look into both solutions. This forum is fantastic!!
Cheers,
Craig -
Michael Gissing
March 29, 2006 at 12:27 amBetter than component out, you could use either the Miranda HDV bridge or the Convergent HD Connect LE, which takes the firewire mpeg and converts it into HDSDI. However, as you have stated that you don’t have a card to take either HD SDI or component, then why not just export an HD uncompressed 10 bit 4.2.2 quicktime from the HDV timeline? Same as rendering with jbrad2’s solution but you go straight to the final QT file without tying up huge amounts of disk space. Uncompressed HD will need around 350gig for the 50 minutes.
