Activity Forums VEGAS Pro What is the best way to add old MPEG2/VOB files to a Bl-ray project?
  • What is the best way to add old MPEG2/VOB files to a Bl-ray project?
    Posted by Paul Gregory on April 8, 2013 at 6:30 am
    What is the best add old SD files taken from a standard SD DVD & incorporate it into a new Blu-ray disk to which I wish to add more resent footage?
    I have an old DVD of when the grand kids were young that is poor quality,since most was shot on old VHSC tapes & then transferred to a SD DVD with motion menus,chapter markers etc. The original camera files are no longer available.
    To this I wish to add new HD files taken much more recently taken as AVC 1080P.
    I know that MPEG2 files can be on the same Blue-ray disk so it seems to make sense to at least have the newer files at much higher quality.
    In DVDA I can open the old mpeg 2 files & get the main VOB files to open. In doing this I loose the chapter markers & even though I can play the first page of the old motion menus that is all I can see.
    I tried importing into Vegas the original files from the DVD but it seems that this isn’t allowed. I even tried changing the VOB file extension to MPEG. This MPEG file opens & plays in several playback programs OK but when I try to open it in Vegas & try to add it to the timeline nothing happens.
    Is there any easier way to get to my goal?
    Thanks in advance
    Paul Gregory replied 13 years, 5 months ago 4 Members · 8 Replies
  • 8 Replies
  • Paul Beller
    April 8, 2013 at 8:32 am
    IMHO the best way is to… drag the vobs to the timeline and that is it. remember – you drop vobs with your film, not vts_01_0.vob nor video_ts.vob
    if your video is split in multiple vobs i think you may have gaps between your vobs dropped on the timeline. so you have to to use a kind of vob2mpg application. it should join your set of vobs and delete any data required by dvd standard which you don’t need in your mpg file.
  • Paul Gregory
    April 9, 2013 at 12:38 am
    I could always use VideoReDo to combine all of the VOB’s into one & the I would have to reset chapter markers before rendering the file out to MPEG2 again. In DVDA I would then have to create a new menu.
    I’m concerned that going this route might cause re rendering with a quality drop. Would this happen?
    If it does then I might also consider dividing the original into a few clips at points where a little stabilization would help. Ideally the whole video needs some sharpening but I have yet to see any video where sharpening really works.
    Thanks in advance
  • Paul Gregory
    April 10, 2013 at 3:27 am
    Just a follow up to the original question. Would either Vegas or DVDA allow the same or easier importing had my original been an ISO file?
    Thanks in advance
  • Jorma Nippala
    April 10, 2013 at 9:02 am
  • Jerry Irving
    April 10, 2013 at 5:26 pm
    Sorry, jumped the gun.
    try what Jorma Nippala suggested.
  • Paul Gregory
    April 11, 2013 at 1:37 am
    But does doing this result in re rendering?
    Thanks in advance
  • Paul Beller
    April 11, 2013 at 9:01 am
    it is not only mpeg2 always gets reencoded in vegas.
    look here: your project is hd, your vob is pal. it must be upscaled, tho it must be reencoded anyway
  • Paul Gregory
    April 12, 2013 at 1:37 am
    I’m certain that you can have both SD & HD on a Blu-Ray disk without re rndering providing that files are compliant for each type & are on separate menu’s. Perhaps someone else would like to confirm this?
    Thanks in advance
