What is the best way of creating your own widescreen bars?
Hi there
Basically Im used to using after effects for doing stuff like widescreen bars because you just make a solid and then put a mask in it, however I have rendered some stuff out and want to change the bars slightly in Premiere. Whats the easiest way of making your own bars, you cant do masks in Premiere can you?
Thanks in advance!
Dan
