Activity › Forums › Apple Final Cut Pro Legacy › What is the best way for adjusting audio levels, across a long project with diffrent levels and many clips.
  • What is the best way for adjusting audio levels, across a long project with diffrent levels and many clips.
    Posted by Torrey Harris on May 13, 2008 at 11:50 pm
    What is the best way for adjusting audio levels across a long project with many clips and diffrent audio situations and diffrent subjects in diffrent enviorments. also the fastest way would be great!!!!
    torrey
    1-225-315-6677
    Torrey Harris replied 18 years, 4 months ago 3 Members · 3 Replies
  • Kevin Monahan
    May 14, 2008 at 12:03 am
    Select Clips > Modify > Levels Dialog will allow you to adjust multiple clips levels relatively or absolutely.
    Hope that helps.
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Andy Mees
    May 14, 2008 at 12:50 am
    if you’re trying to normalise the audio accross all these different clips then the “Normalize Gain” filter in FCP 6 may help https://www.larryjordan.biz/articles/lj_normalizing_audio.html
    or course this is just going to bring all your peaks to the same level, but it may well get you in a goosd place to start your manual adjustment using your ears and meters toolset 🙂
  • Torrey Harris
    May 14, 2008 at 2:00 am
    when u say select clips u mean highlight all clips then select modify, because i can’t find select clips in any of the pull down menus in final cut
    torrey
    lt prod
