Activity › Forums › Adobe Premiere Pro › What is the best Keyer for Premiere Pro CS4?
  • What is the best Keyer for Premiere Pro CS4?
    Posted by Richard Stegall on February 16, 2010 at 7:45 pm
    If you were going to Key in Premiere Pro CS4 what would be the very best option? I see Primatte is good but I just wanted some other opinions. Has anyone heard of Ultra Key? (Not Ultra CS3)
    David b. Monier-williams replied 15 years, 8 months ago 4 Members · 4 Replies
  • Vince Becquiot
    February 16, 2010 at 8:38 pm
    Primatte is one of my favorites. However, it’s mostly an After Effects toy. While you might get it to work in Premiere, it will be likely frustrating as many functions won’t work. The premiere interface also doesn’t lend itself well for compositing.
    And finally, for good keying, you need masks, not available in Premiere.
    The workflow I prefer is copying and pasting clips between Premiere and After Effects, then rendering back out and replacing in Premiere.
    You can copy clips from PP project panel to After Effect panel, but also from premiere timeline to After effects composition.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Alan Lloyd
    February 17, 2010 at 12:28 am
    What kind of keying? Greenscreen? Luminance? Difference matte?
    I can often manage a decent greenscreen key in PPro simply by lighting it well (scopes are your best friends here) and careful tweaking. I even did a nice luma key this week for a client by using a locked-down camera and stopping down to grab enough footage out the otherwise blown-out window to composite it – in PPro, without touching After Effects. Took a few layers and a little twiddling, but it worked.
  • Richard Stegall
    February 17, 2010 at 7:14 pm
    I guess I will just stick with Primatte in AE. The workflow is just so much better in PP. Thanks for all of the input. I just want to make sure there wasnt a better option than using AE.
  • David b. Monier-williams
    January 7, 2011 at 5:39 pm
    I have a Greenscreen clip in my CS4 project. I have white curly hair. I applied 25% similarity. It still leaves me with a slight green halo around my head, instead of my usual gold one. It also leaves a slight green halo around my blue blazer. Using Blend, Threshold, Smoothing doesn’t seem to help. I’m an AE ignoramus. What to do?
    Any help would be appreciated.
    David
