What is the benefit of XDCam versus straight hard drive?
The gig I’m working on still shoots DVCPro tape and they want to transition to XDCam. We will likely be editing in an offline low-res codec and then upres-ing later (that’s what we do now with the tapes.) I just spent three hours reading forum posts about Avid-XDCam workflows and I’m still confused, so here I am.
From what I can tell, my options for offline-online editing with XDCam are this:
- AMA link and transcode each individual disc to a low resolution one-at-a-time. Edit. Upres by re-linking and re-transcoding each individual disc to a high resolution one-at-a-time.
(It seems very tedious to link and transcode each tape one-by-one as opposed to batch capturing the way we do with tapes now.) - Import the files from each individual disc at a low resolution. Edit. Upres by batch importing the files one disc at a time at a high resolution.
(It seems very tedious to bath import one-at-a-time, plus it would require importing an entire 20-minute clip if a few seconds were used in the sequence.) - Treat the discs like tapes and digitize real-time with a deck. Edit. Upres by decomposing and batch capturing the clips one-disc-at-a-time at a high resolution.
(This would be the easiest upres, but it seems ridiculous to capture digital video files in real-time.) - Back up each tape to a single hard drive. Link and transcode all files at once to low-res. Edit. Upres by relinking all-at-once and transcoding all-at-once to a high resolution.
(This is clearly the easiest and fastest workflow, but it requires a lot of disc space.)
SO MY QUESTION IS:
Assuming I use workflow #4, what is the point of shooting to XDcam as opposed to shooting straight to a card/drive? If we’re going to have to back up all of the media to a drive anyway, wouldn’t it be way cheaper to just use a second hard drive as a backup instead of a large collection of XDCam discs?Thanks!
Using Avid MC 6.5 on Mac OSX 10.7 - AMA link and transcode each individual disc to a low resolution one-at-a-time. Edit. Upres by re-linking and re-transcoding each individual disc to a high resolution one-at-a-time.
