Activity Forums Apple Final Cut Pro Legacy What is “General error (27)?”
  • What is “General error (27)?”
    Posted by Kylecine on July 27, 2005 at 5:13 am
    Got this message when I tried to open a project. What’s it mean? It may help me understand the plethora of other problems I’m experiencing (see the previous few posts in the previous 20 or so minutes…I’m going nuts here).
    Kyle
    David Roth weiss replied 21 years, 2 months ago 2 Members · 1 Reply
  • David Roth weiss
    July 27, 2005 at 6:20 am
    Kyle,
    Let me make a suggestion to you. Take your Sonnet Tempo-X 8-port ESATA card out and see how your machine works without it. If its not any better you can rule that card out and move on to the next component you added and take that out and test. Use a scientific approach and eliminate whatever bad component(s) you might have installed. You may have also installed a bad memory module, and each of those should be ruled out. If you can’t ID a bad compenet then maybe you have a bad motherboard and you’ll have to bring the whole thing back to wherever you bought it.
