Activity Forums Avid Media Composer what is errcode:-6662
  • what is errcode:-6662
    Posted by Avi Lev on March 5, 2011 at 3:41 pm
    Using MC 5.0.3 I’m trying to export a 2 min scene into H264 file. After a short moment it crashes and a Avid Media Composer note says; Exeption:Movie export from procedures FAILED!, errcode:-6662
    On the time line I have a mixed down video and six audio tracks some of them EQ treated .
    Avi
    Lindsay Simpson replied 15 years, 6 months ago 3 Members · 3 Replies
  • Jeff Greenberg
    March 5, 2011 at 8:47 pm
    Can you get it out at all? QuickTime Ref? How about to squeeze (where the tools for h.264 are stronger)
    Best,
    Jeff G
    Apple Master Trainer
    Avid Cert. Instructor DS/MC
    Avid & Color Videos Vasst.com
    Compressor Essentials Lynda.com
  • Avi Lev
    March 5, 2011 at 10:32 pm
    So far, the only way I can do it is export as QT Same as Source.
  • Lindsay Simpson
    March 11, 2011 at 8:28 pm
    I have had similar issues exporting H264 or really anything for that matter other than ‘same as source’ directly out of Avid. The work around I’ve come up with to create H264 files for the web is to ‘File’>> ‘Send To’>> ‘Sorenson Squeeze’. When the prompt box opens for sorenson, I click ‘options’ next to ‘Sorenson Squeeze Export 1’. In these options you can set your H264 parameters, kbit rate etc. After clicking ‘ok’ Avid will start exporting, just be sure you know where your new file will be saved. When it’s done Sorenson will open with the H264 file loaded. I close Sorenson ASAP, and grab my H264, usually saved to the desktop, and transfer elsewhere.
    Depending on what type of media you have in your sequence, you might require video/audio mixdowns before export. Any time I have long GOP media mixed with something else I find a video mixdown often save headache when it comes time to export.
    I’ve tried these exports on Squeeze too, but the application seems to fail no matter what I’m attempting to squeeze.
    Good luck,
    Lindsay
