Activity › Forums › Adobe After Effects › What is “Enable Auto Save2”?
  • Joseph W. bourke
    March 21, 2013 at 5:49 pm
    Auto Save should properly be called Auto Save Our *sses. It’s a backup scheme which automatically saves a copy of your project at the selected interval, “10” being every ten minutes. Max Project Vers means that it will save up to 5 backup copies. Enable Autosave with a 1 means that it’s “true” – Autosave is turned on. With a 0, it means it’s turned off. I generally set my autosave to 20 minutes, but I also make constant incremental saves as I’m working, such as “ProjectOpen_1”, “ProjectOpen_2”, “ProjectOpen_REV1” (for client revisions), and so on.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Greg Neumayer
    March 21, 2013 at 6:06 pm
    Indeed. It saves almost as good as Jesus. But I’m actually wondering about the “Auto Save2” listed in the pref file.
    Antifreeze Design
    https://www.antifreezedesign.com
  • Joseph W. bourke
    March 21, 2013 at 10:26 pm
    I believe that “AutoSave2=1” is merely the switch that turns auto save on or off. I thought I explained that above, but at any rate – I think the 2 is meaningless. This is merely the “switch” that says whether AutoSave is turned on or off.
    I suggest you give it a try, and change the 1 to 0. My guess is that it will disable AutoSave. The 1 usually means “true”, the 0 means “false”. It will either disable AutoSave, or delete After Effects, crash your machine, and remove all the money from your bank account. :>)
    Joe Bourke
    Bourke Media
  • Greg Neumayer
    March 21, 2013 at 11:39 pm
    Bummer. I was hoping that “2” was shorthand for “to..” Probably just their second version of the functionality.
    Antifreeze Design
  • Todd Kopriva
    March 22, 2013 at 2:33 pm
    Just a warning:
    In general, directly manipulating the preferences in the text file exposes you to untested and unsupported behaviors. Be careful in there.
    The preferences that we expect you to manipulate are the ones exposed in the Preferences dialog box and other parts of the After Effects user interface.
    After Effects team blog
  • Greg Neumayer
    March 22, 2013 at 4:36 pm
    Todd, now you’re just tempting us!
    Warning noted. 🙂
    Antifreeze Design
