Activity › Forums › VEGAS Pro › What is done first
  • What is done first
    Posted by Paul Gregory on September 16, 2010 at 6:56 am
    When you use programs like Mercalli for stabilization you are required to do a scan of the clip. The playback often has shimmering sections around the center core of your original clip. To remove this shimmering area you need to use the pan/crop tools.
    My question is this what should be done first cropping or stabilization? In other words does Mercalli look at the entire original clip before you cropped it or not?
    Thanks in advance
    Steve Rhoden replied 16 years ago 2 Members · 1 Reply
  • Steve Rhoden
    September 16, 2010 at 7:33 am
    No need to use the pan crop tools in vegas or any cropping first.
    Just highlight the video event you are working on and just drop
    the Mercalli filter on it, select from a long list of
    presets what you want or toggle to your preference and then
    click the analysis button. You can Then Ram preview the results before
    you render.
    Steve Rhoden
    (Cow Leader)
    Creative Arts Director and Film Maker.
    Project Samples at:
    http://www.youtube.com/hentys
