Activity › Forums › Adobe After Effects › What is Disk Cache: Read Only in Render Settings do?
Posted by Sebastian Lee on December 14, 2013 at 2:28 amI know what is a disk cache. But read only means?
David Kinsey replied 12 years, 1 month ago 3 Members · 2 Replies -
Todd Kopriva
December 14, 2013 at 7:31 amIt means that the disk cache is not written to during renders for final export if you have that set.
After Effects team blog
David Kinsey
August 8, 2014 at 9:03 pmHi Todd,
Learning AE from scratch the past few months. Started to think there must be a way to use the rendering process to create RAM previewed frames for the same comp over the same time period. Sorry if I’m using the terminology awkwardly. Let me try another way, let’s say I have a comp named “CompA” and I don’t have many “RAM preview” frames in the timeline. I render out the first 30 seconds to an AVI using the Render Queue. When the render is over is there some settings in preferences or in the renderer that would tell AE, “Hey, now that we’ve finished all that hard work, let’s make it available in the RAM preview!” If such a feature does not yet exist, that would be an exceptionally helpful bonus from the rendering process, yeah?
– DLK
