[Jonathan LaPointe] “the Colorist has referred to a tool he calls the “Aperture Correction” tool. “
From the article:
The aperture correction in the foreground makes you focus more on the objects in the foreground.
There are three options inside the detail enhancement tool; blur, sharpen, and mist, which all have +/- values, that will either sharpen or blur, depending on where the fulcrum is and whether you are working inside or outside of a qualification area. Aperture Correction is getting to be a bit of a legacy word, because we are starting to slide toward post-depth-of-field, rather than setting an aperture-defined circle of confusion, related to exposure and emulsion speed. In the case of Prometheus, as dark as it is as discussed, it would start becoming a challenge to control focal depth, compounded by going to higher and higher aspect ratios. Obviously it is easier to blur an image than it is to convincingly sharpen it — my own preference would have been to shoot a scene with as high a T-stop as possible to get the deepest focus, then z-depth qualify the scene (using whatever options there might be, given the camera, which might include some 3D solutions, but software like Mocha can also solve for camera positional data from 2-D) and then actually blur instead of sharpen — which would more closely resemble the old “coring” function in electronic imaging.
Back in the early ’80s we most often referred to “sharpening” or “detail enhancement” as phony-focus.
jPo
“I always pass on free advice — its never of any use to me” Oscar Wilde.
