Activity Forums Adobe After Effects What is a simple trick to fix white levels?
  • What is a simple trick to fix white levels?
    Posted by Milton Hockman on January 26, 2006 at 8:39 pm
    I made an animation with a white solid as the background layer. When i bring it into avid and play it in the sequence it is all messed up on my tv monitor cause the white levels are too high. I fix it in avid with the color effect, but what is a simple way to do it in AE?
    i imagine an adjustment layer with a filter but what filter?
    Steve Roberts replied 20 years, 3 months ago 2 Members · 2 Replies
  • Steve Roberts
    January 26, 2006 at 8:41 pm
    When you create the white solid, you can set its colour to RGB 235, not RGB 255. If the solid exists, you can change its colour properties with shift-ctrl-Y (shift-cmd-Y).
  • Steve Roberts
    January 26, 2006 at 8:47 pm
    … but if you want to change the levels for the whole frame, you apply effect>adjust>levels to an adjustment layer (if you have multiple layers, otherwise just apply it to the footage layer), setting the outs to 16 and 235 for broadcast.
    Steve
