Activity › Forums › Adobe Premiere Pro › What is 1080/50p (or 1080/60p)?
Posted by Adam Spencer on October 13, 2012 at 11:10 pmI’m looking at getting a camcorder that records in 1080/50p, but I simply cannot find a decent explanation of it.
Why was this format introduced and what are the benefits? I can only deduce that the camera is recording at 50/60fps for the purpose of smooth motion. I’m guessing the motion is interpolated once you output a rendered file at 25fps, thus giving smoother pans than you otherwise would shooting in 24p. Or am I way off-base here?
Also, does Premiere support this format natively now?
thanks
Taz Bari replied 13 years, 5 months ago 5 Members · 5 Replies -
Walter Soyka
October 15, 2012 at 1:16 am[Adam Spencer] “I’m looking at getting a camcorder that records in 1080/50p, but I simply cannot find a decent explanation of it.”
1080p/50 is 1920×1080 HD video with 50 full (progressive) frames per second. Before 1080p50, you had two choices: 1080p/25, with 25 progressive frames per second, or 1080i/25, with 25 interlaced frames (or 50 half-height fields) per second.
1080i/25 essentially sacrifices spatial resolution (fewer vertical lines) for temporal resolution (more fields per second) when compared with 1080p/25. 1080p/50 gives you the best of both worlds: the entire spatial resolution of a full progressive frame and the increased temporal resolution of 25i video.
To go back to 1080i/25 or 1080p/25 from a 1080p/50 source, you’ll have to give up either that added partial or temporal resolution.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Rob White
November 16, 2012 at 8:20 amHi Walter,
Do you have any recommended export setting for 1080/50p footage?
I’ve used the Sony NEX-FS100 camera and captured on to an Atomos Ninja.
I would like to output for Web (YouTube).
Any help is appreciated.
Rob White -
Walter Soyka
November 16, 2012 at 3:01 pm[Rob White] “Do you have any recommended export setting for 1080/50p footage? … I would like to output for Web (YouTube).”
Sorry, mate, I’m not too familiar with YouTube’s compression standards, and I don’t know if it actually even supports 1080/50p.
You could try modifying Adobe Media Encoder’s “YouTube 1080p 25” preset; you’ll have to bump the level (located in the “Basic Video Settings” section directly underneath “Profile”) up to 4.2 (IIRC) to allow 1080/50p.
Walter Soyka
George Kalogeris
March 2, 2013 at 11:15 pmI thought I wouldn’t need to start another thread.
recommended settings for exporting to file from CS6 ?
I have 1080/50p footage from Sony NEX-EA50
and I ‘d like to do some renderless cut-joins -
Taz Bari
April 20, 2013 at 12:40 pmHi
My question is that if you convert the 50p to 25 does it effect the speed of the shot. From my basic understanding when we change frame rates speed changes so i assume if i convert it to 25fps it will change the speed.
Im working on a music video with lots of tracks and effects and all the footage is 50p and i am worried that once the video is done and i have to convert it to 25fps to put online or send to a channel that the speed will all change and the video will become out of sync. Sorry if this sounds stupid but im paranoid as this is the first music video i am making.
